Here is a list of all the postings hth has made in our forums. Click on a thread name to jump to the thread.
Thread: Harrison L5 clutch adjustment |
22/06/2016 09:34:30 |
Hi
I am not qualified to offer advice, but I do have a L5 myself . The only comment I can make is, the clutch in my L5 makes a horrible rattling noise . I can reduce the annoying rattle with the speed control knob on the VFD - at certain RPM's the noise is almost gone. Reading the lathes .uk information, Tony writes , the L5 clutch is known to be noisy . My L5 clutch does function well. Mike |
Thread: Stuck chuck |
20/06/2016 09:33:04 |
Hi
You are in Australia ?
This might help http://www.model-engineer.co.uk/forums/postings.asp?th=118159
Thread: Oil nipples thread size ? |
16/06/2016 10:48:58 |
hi
Thanks to everyone Yes the thread is likely to be BSPT As for making an oil gun, I purchased a grease gun and modified it as described here , this is ideal for the common ZERK nipples http://www.metalwebnews.com/howto/oilgun/gunconvert.html
Edited By hth on 16/06/2016 10:51:02 |
16/06/2016 09:06:17 |
Does anybody know what type of oil gun would be suitable for these nipples ? I have a quantity of these , the thread maybe 1/8 GAS but not sure . |
15/06/2016 11:48:00 |
My Kerry AG lathe seems to be fitted mostly with 1/4" BSF zerk type nipples . Were these particular BSF lube fittings a commonly used size on British built machinery ? I think Myford used #2 BA threads . The Kerry also has a few non zerk nipples , these look similar to zerk, but are without the round ball .
Edited By hth on 15/06/2016 11:50:58 |
Thread: Harrison L5 new to me |
12/06/2016 14:23:21 |
My bad drawing but you get the idea
12/06/2016 13:45:57 |
Oldskool
It is a common problem with lathes that have been left unused for years . I have had this problem myself . The solution I found worked for me . I remove the lid of the headstock, I then use a jaw that I have taken out of a chuck, I use the jaw as a brake, I slide the jaw between the headstock casing and the large bull gear - doing this locks the spindle . The jaw has teeth, the teeth will slide into the large gear , locking it |
Thread: Protecting our Dark Skies |
11/06/2016 10:03:10 |
I was down at the Southern tip of Tasmania in 1974, the sky at night was breathtaking, the clarity , stars and the whole massive universe . Never seen anything like it since . |
Thread: Kerry AG lathe |
15/05/2016 09:26:50 |
Thanks to everyone . |
14/05/2016 14:13:34 |
Hi Michael Thanks for the reply
Would the cork upset the process of leveling the bed and keeping the bed level . The lathe bed would be sitting on a lump of jelly ? |
14/05/2016 13:53:25 |
Hi
Well I have discovered a odd thing about the Kerry , maybe Kerry did this for some reason. There is a layer of cork between the bed and the base . Why ? This pic is from the lathes uk site . My Kerry also has a 3/16" thick cork gasket as indicated on the pic . If it isn't cork, then its some kind of insulation.
Edited By hth on 14/05/2016 13:55:18 Edited By hth on 14/05/2016 13:56:10 |
Thread: What is this designed to do |
09/05/2016 12:05:57 |
Hi I recently found this device, it has a Mercer .0005" dial indicator on it . There is a flat machined onto the bar directly beneath the dial probe .
It has the following crudely stamped onto the tag
THIS INDICATOR IS FITTED WITH A DIAMOND BUTTON PLEASE LOWER ONTO STORE DO NOT ALLOW TO DROP FREELY Edited By hth on 09/05/2016 12:08:32 Edited By hth on 09/05/2016 12:10:42 |
Thread: Dipstick in tailstock |
06/05/2016 12:13:51 |
The old Holbrook also has a relieving setup. The manual explains , this is for making things like taps, hobs and spiral reamers. The old lathe weighs in at 1400 Kg. |
06/05/2016 09:19:40 |
Ah that explains it . |
06/05/2016 09:14:02 |
I wonder if this feature was used in any other lathe ? My vintage Holbrook T13 has this unusual accessory !
Thread: Marconi works |
01/05/2016 09:10:45 |
The lathe in the foreground looks like a early Colchester Master . The operator staring at the camera has placed a board on the bed , a place for his tools . Yes , it looks to be a posed scene. |
Thread: Modernise your workshop |
01/05/2016 04:36:51 |
with Govt. surplus tools
01/05/2016 04:22:51 |
I came across this pic of the Marconi works. I can't believe they had so many lathes . Manufacturing wireless equipment ? Must be the lunch break, because the machinery is not moving !
29/04/2016 09:11:14 |
Hi again Been looking for a manual for the Kerry AG mk3 , no luck. The Kerry manuals available are for the larger models .
Regards Mike |
28/04/2016 12:18:00 |
Posted by Michael Gilligan on 28/04/2016 10:17:20:
Treat her well, and I think you should be very happy together. MichaelG. . P.S. ... The 'ribbed flat belt' may turn out to be a Poly-Vee which someone has used as a substitute ... Have a look for any identification marks, and/or post a close-up photo, please. Edited By Michael Gilligan on 28/04/2016 10:36:52
Hi Michael The odd looking belt does have the basic appearance of a modern Poly belt, but it is made from a canvas rubberized material . I would say it is the original belt from the 1960's. The V groove spacing in the two Kerry pulley's is very narrow, unlike the poly pullies you see around today. Will take a pic tomorrow , its night time here right now - the time difference ! Cheers Mike
Edited By hth on 28/04/2016 12:19:22 |
