Member postings for Jim Harp
Here is a list of all the postings Jim Harp has made in our forums. Click on a thread name to jump to the thread.
Thread: Jock Miller's Taper Turning Attachment.
30/01/2018 01:31:41
Yes thanks for the explanation Neil, I should have said that earlier. This is the first taper attachment plan I've ever seen that didn't require either a telescoping crossfeed screw, or disconnecting the screw.
Jim
26/01/2018 13:56:04
Thank you for all the comments. I think I've got it now, I was failing to note that the yoke or clevis connecting the anchor link to part A could pivot. Sometimes I can't see the forest for the trees!
Congratulations to Mr. Miller on a very clever piece of work. My only suggestion would be to add a reference surface to part A so that a sine bar could be used to set the angle the guide bar.
Jim
25/01/2018 23:14:04
I'm having trouble visualizing this. Does the base (Part A) for the guide bar move in an arc when the cross slide is moved toward the operator to put on the cut? If so, does this not cause a small change in the angle of the taper with each succeeding cut? Thanks.
Jim
Thread: Subscription expiration date?
20/03/2016 01:56:39
Thank you Dave. Good thing it's not a snake, I'd have been bit if it were.
Jim
19/03/2016 00:38:36
How can I find the expiration date for my digital subscription, I have searched but haven't found it. I'm a USA subscriber, and don't want to let the subscription expire. Thank you.
Jim Harp
Thread: Where are the buttons?
04/11/2013 00:17:20
Thanks again JasonB;
I'll watch for the alert.
Jim
03/11/2013 02:17:24
Thanks Jason and Jim;
Guess I missed the announcement of the change.
I have been searching for, but not finding renewal instructions.
Jim
02/11/2013 19:45:26
What happened to the option to select My Digital Editions after signing in?
Also I can't find a My Account button so I can check the status of my subscription. I have the digital only subscription which I believe should still be valid. Thanks.
Jim Harp
