Here is a list of all the postings Gra has made in our forums. Click on a thread name to jump to the thread.
Thread: SIMAT 101 - Changing the belt? |
28/03/2020 09:28:24 |
Many thanks James. I have a new belt, just couldn't remember how the gearing came apart to fit it! All done and back up and running again. Graham |
27/03/2020 13:07:04 |
Hi Folks, Does anyone know how to remove the pulleys and shaft from a simat 101 headstock to replace the V belt, mine's worn thin and needs replacing. Cheers, Gra |
Thread: simat 101 backgear |
19/12/2012 09:45:11 |
Hi Brian, If you look at one of the centre pulleys on the headstock, there is a small grub screw, loosen this with an allen key and then engage the backgear by bringing the lever and gears forward towards you. This will give you a 4:1 reduction ratio on any speed depending on the pulleys used. Remember to tighten the grub screw back up though when you have finished using the back gear! Hope this helps. Regards, Gra |
