Here is a list of all the postings Bob Worsley has made in our forums. Click on a thread name to jump to the thread.
Thread: Allchin 1.1.2" boiler |
07/11/2019 18:42:46 |
That is exactly it. Perhaps it is time the drawings were updated to reflect modern construction methods?
Thread: Another unfortunate milestone reached? |
07/11/2019 18:38:33 |
Received a flyer in my Machinery Market magazine today, a glossy advertising the shutting down and selling off of Electro Motion's largest sales building. For sale are over 600 machines, from the photos mostly manual or early auto types. Does this mean that manual machines are now scrap? If it hasn't got a colour screen and 15 software updates a month then no one wants it? I remember visiting Nettlehams at Gainsborough about 20 years ago. They were in the same position, no one bought what they sold, place turned into a supermarket I think. I have personally experienced the same with electronic test equipment. Analogue scopes, spectrum analysers, signal generators plus just about every other type of non-colour LCD screen equipment is scrap. I know, I scrapped about 70 Tektronix and HP analogue scopes few years back, worthless. Is this good, or bad? That you now have trouble finding a machine that will do a serious job without needing software is an advance, or not? Is the thing to do to salt away old mills and lathes, a Parkson for £400 doesn't sound expensive, or big old Colchester lathes, radial arm drills, even trivial stuff like a drill grinder. Feels to me that this isn't good. The lack of any software in a machine is good. Starting out don't you need simple, reliable and cheap tools?
07/11/2019 10:42:59 |
No! Do not confuse brazing with braze welding, or bronze welding. Brazing uses what is in effect a piece of brass to join the parts, and it also requires a few thou gap for the spelter to run in by capillary action. Braze welding uses a different type of filler that will only form a fillet. Added to that the throatplate joint will be made after other joints, tubes etc, so they also would need to be braze welded due to the far higher temperature this requires. No one has picked up on my point about pinholes and the possibility of them opening up under steam pressure. If the method of construction requires a change, then what is wrong with that? I would plan to use metric threads rather than inch, another change. If you read the Haining book about boilers for ploughing engines then he talks about the Greenly method of boiler design, but that is thickness of metal, not that they think a line joint several inches long is good enough for 100psi.
06/11/2019 11:37:47 |
The Allchin barrel is made from a short piece of tube joined to a wrapped sheet that goes over the firebox. Figure 2.1 in the book shows the join between these two pieces. What I don't understand is that the throatplate just touches the underside of the barrel and is soldered there. There is no folded flange going inside the barrel to make a decent area to solder. The drawing just shows a line join between the throatplate and barrel. I have done a search of the forum and can find no mention of this. The figure 2.1 also shows the waisting of the firebox wrapper which is far more than the 1/32" on the drawing. As far as I can see the throatplate needs flanging on the sides backwards into the firebox and forwards into the barrel. This makes for an interesting shape to the copper where the backwards flange meets up with the forwards flange. Must be possible, I imagine all loco type boilers have this double bend at this point, but can't find a photo of one in my limited collection of books. The point is that at two points one either side, there seems to be a pinhole gap in the flange where it touches the wrapper and barrel. It also seems to be impossible to reinforce this point with some copper. This raises the question that is 13SWG copper sufficiently strong that if this pin hole leaks then the copper has sufficient strength not to tear and cause the boiler to fail? I can find no intelligible information about how strong copper is in tension. If you had the 100PSI steam in the boiler and drilled a hole in the shell, would the steam just rush out or would the boiler explode? Is the tensile strength of the copper greater than the tearing force from the steam? What size hole would there have to be before the steam exceeded the strength of the copper? Why wasn't the boiler made with the barrel split and folded down? But this also raises the question that the sides would need to be extended by a small amount. Instructions for other boilers say to rivet these extensions then solder. But again there are now four places where this strap butts up against the flanges at the front throatplate and rear backhead. Is this another source of weakness? Reading scientific how to books (Materials and Techniques for Electron Tubes by Kohl) where they use silver soldering and the gap between the two pieces is given as 0.0015" to 0.010" (p382). This is not very much after walloping the copper to flange it. Ok, can clean up the front tube plate on a lathe, but all the others are just filed, 0.010" is a scratch. The scientific book specifically mentions solder dams where it can't flow past a scratch in the joint. For example the wrapper side extension pieces. Do you put some flux in the between the side pieces and the reinforcing strap before riveting. Then what happens when it is heated up, has the flux dried? Is it hard and holding the pieces apart? Is assuming the flux will get inside the joint by placing on and around good enough? How do you know any solder has actually gone inside the joint? Don't forget we are looking at just 0.010" gap here. The join between the barrel wrapper is made with a piece of 5/8" strip copper, this is 5/16" on each surface. Where is there any figures for the shear strength of copper and soldered joints that this is adequate. With the stresses on this joint from the model moving then this is needed? The steam pressure on this joint at 100PSI is 1104 pounds, or nearly 1000psi tensile. Does this need to be addressed? Is is a problem? Tilting at windmills?
Thread: Graham Howard and Brunell Steam Model Engineering |
28/04/2019 17:35:10 |
Wow, has Graham Howard of Brunell Steam Model Engineering been resurrected? About seven years ago, I bought a complete set of everything for the Fowler ploughing engine from Graham Howard at Brunell, costing £2,300. I assume this is the same one. I am still waiting for most of the castings plus all the other odds and ends, strakes, rims etc to be delivered. The said Graham Howard ignores phone calls, emails and posted letters. Just how do you communicate with someone like this. It would be really nice, even now, to get my order completed. Would Graham Howard of Brunell like to comment on this forum?
Thread: DRO using a wire |
08/08/2014 20:35:15 |
Ah, it is nice to be remembered! Yes, I still make a limited range of the draw wire sensors and displays, just the two axis now, run out of labels for the three axis. Expensive! They were £390 for a two axis DRO when I started making them in 1992, and the price is still £390, gotta live.
