Member postings for Ross Duncan
Here is a list of all the postings Ross Duncan has made in our forums. Click on a thread name to jump to the thread.
Thread: best online supply company
28/09/2013 20:23:29
thanks, yeah you'd be right... Its tee nuts I need
28/09/2013 20:13:02
I have a bridgeport 2j, I need a dial indicator, mounting parts and some T-slots to fix my vise on to the table, would anyone recommend a good place to buy these? other than ebay. Thanks
Thread: Bridgeport 2j
25/09/2013 20:24:44
Thanks for all your suggestions. Much appreciated, think ill paint the machine any type of paint? Also what oil to use, and should I just manually oil the lead screws and the ways, and any other parts? Ha ha and one other thing, any tips on removing coolant from the sump?
25/09/2013 13:03:20
image.jpgimage.jpgimage.jpgimage.jpgJust took delivery of a Bridgeport milling machine, I wondering what is the best way of cleaning it? Plus any thing that you think that would be useful for me to know. Also does the machine not need or have a one shot lube system? And how do I get the old coolent from the sump?
Thread: bridgeport BR2J
19/09/2013 15:38:18
thanks for the advise, I've been offered this machine for a crazy price (600), the guy has had it from new and only has machined aluminium. So I'm prepared to take the chance that something will go wrong, for that kind of money.
18/09/2013 23:04:33
Thanks for your reply, very helpful. You wouldnt know if I would need a single phase to 3 phase 240v inverter or a single phase to 3phase 415v inverter?
18/09/2013 22:06:35
I have been looking into buying a bridgeport br2j with vari speed head. Please could someone help me out on what single to 3 phase inverter I need to buy?
Thread: DENFORD MILLING MACHINE
12/08/2013 08:48:14
Ok that's good to know. Is getting a rotary phase converter a viable option as well?
11/08/2013 23:08:29
Hello I'm interested on this ebay auction
http://www.ebay.co.uk/itm/281147960188?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I was looking to see if a phase 3 inverter would work to power his milling machine? I understand that to do this, wiring must be in delta?
Any help or suggestions would be great, thanks
Thread: Help with start up?
03/10/2012 18:35:05
Hello I'm looking to buy a lathe and a mill, I have posted on this forum to ask what would be best for the job.
The Lathe :-
basically I'm looking to cut 2, 1 mm notchs in a 1 inch long 8mm diameter iron round bar then put a m4 thread inside it. I also need to lathe 14mm long 6mm diameter brass.
The mill :-
I would like the mill out mild steel or iron dimensions LWH 70mm x 70mm x 17mm
Hope this helps I'm a total beginner to this, looking for someone to advise on what mill and lathe to buy or what combo to buy, I've got a £1000 to spend. really just looking for something that will do the job. also my workshop is in my spare room on the second floor, so i need to be able to get it upstairs.
Please Help!
