Member postings for john Chappell 1
Here is a list of all the postings john Chappell 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Lever Action Tailstock Design and Build
16/03/2023 00:06:25
Thank you, I will look it up.
01/03/2023 03:45:48
John Chappell
Has anyone modified a Super 7 ?
Thread: Steam regulator
06/02/2021 01:33:12
Hi All . Thank you. i now have all the information i need.
I am amazed at how well the system works.
Thanks again,
Regards, John Chappell
05/02/2021 01:12:13
Could some please advise what issue/s of ME that had an article about using ball valves as steam regulators on steam locos
Thread: Muncaster's Simple Entablature Engine
07/12/2019 23:47:00
Hi Folks, I forgot to add my email address:-
[email protected]
07/12/2019 22:05:12
Hi Jason,
I have a problem. I want to but 2 Muncaster flywheels from lee but he doesn't post to Australia.
Could I ask if a fellow ME in England buy 2 for me and post to me here in Australia ? I would of course send over the money. It would be easier if the person has a Pay Pal account. They could find out from the local Royal mail PO how much it would cost for postage and add on some more for their troubles.
John Chappell,
30 Lamerough Pde,
Caloundra QLD 4551 ( Sunshine Coast 100 Kms north of Brisbane )
18/11/2019 23:00:18
Regarding bending exhaust pipe.
I selected a piece of pipe longer than needed, crimped one end and then filled the pipe with solder.I then bent the pipe with my home made pipe bender, threaded one end ( reversing the die to finish up close to the bend ), cut off to length, deburr and finally heat up and pour out the solder.
Worked well for me!
10/11/2019 20:51:20
Thanks Jason. Very good news... but he doesn't post to Australia! so how is one to buy? I wanted to buy 2 or more if others in Australia would like them
01/11/2019 02:54:19
Here are the photos!
Edited By JasonB on 01/11/2019 06:55:32
28/10/2019 22:03:40
Hi Jason,
Attached photos of my build so far. By the way I used your method to make the cross head guides, Thanks.
It may be of interest to others how I made a poor mans "soft jaws." for machining the cylinder cover. I bored out 3 large nuts to fit over the chuck jaws and added grub screws to hold them on the jaws. In this case I tightened up jaws on the nuts and then bored out a recess slightly smaller than the OD of the cover.
ps sorry I could not work out how to insert photos
11/10/2019 23:22:00
Thanks Jason,
I think I will look into doing it with the CNC mill.
11/10/2019 10:26:32
Thanks Jason,
So the guides are actually pieces silver soldered together?
11/10/2019 07:38:39
Hi Jason,
Thanks. Yes I am up to issue 4620 but awaiting some cast iron. 60 Dia mm as far as I can see you can't get it out of 50mm. Where is the extract for the gland?
I am using a Wabeco CNC mill for some parts it makes things much easier.
It would have been helpful if you could have given a list of materials when the series started as where I live I have to order from a company 2000KMS AWAY and have to wait quite a while for delivery.
Keep up the good work,
Sunshine coast , Australia
11/10/2019 05:51:43
Hi Jason,
In ME 4621 pp 457 Why are crosshead guides not symmetrical? ( mirror image )
Diamension 55.3 + 23.5 does not add up to 79.5 mm.
REGARDS,
John Chappell
