Here is a list of all the postings Mark Harris 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Fobco 7/8 |
03/11/2022 18:15:40 |
Mine appears act as a one way clutch. Does yours do the same |
Thread: Jones & Shipman 540 |
01/11/2022 07:36:21 |
Posted by Mark Rand on 30/10/2022 20:50:18:
Make sure you use a 5/16" BSW screw, or it won't fit the spanner.
I would have thought 1 1/8” uns would be better 😂 |
Thread: Fobco 7/8 |
30/10/2022 19:53:33 |
30/10/2022 19:53:16 |
30/10/2022 18:54:42 |
My 7/8 must be different yours then ! |
30/10/2022 18:36:02 |
Yes thank you was looking at the picture online and didn’t get it. But this what I thought it would look like. |
30/10/2022 17:28:25 |
Has anyone got a wheel/ hub puller tool for a Jones & Shipman 540 ? And if so could you post a picture of it so I can make one. Many thanks in advance Mark |
Thread: Fobco 7/8 |
30/10/2022 17:24:26 |
Posted by Ian Parkin on 29/10/2022 19:09:21:
The hole near the front has a spring in it with the ball the hole behind lets you release the ball Thanks for the reply I’m assuming that your picture is of a Fobco Star !? There is a one hole underneath that feels like it has a ball bearing in it. It does release the drum to spin both ways if I insert a screwdriver. I have now found out that the contractor inside has a burnt out coil. So I’m trying to source one the will fit inside the machine. Thank you to everyone else who replied. mark |
29/10/2022 17:54:23 |
I acquired a 7/8 Fobco drill press today along with Jones and Shipman 540surface grinder . The drill press is a non runner. I’m hoping it’s an easy fix. But I noticed the quill does not return had quick look and no return spring. Lathes .co.uk do the spring so no problem there but the housing just spins does anyone have a drawing of this assembly or a manual please. I am also looking for a manual and any useful info on the surface grinder. Many thanks in advance Mark. |
