Here is a list of all the postings wavering has made in our forums. Click on a thread name to jump to the thread.
Thread: Turned items are not looking good ... |
19/08/2012 20:22:22 |
Posted by Springbok on 16/08/2012 01:40:30:
Hi I have been sitting back and watching this one, looking at the pics the 2 large bits of kit in what would look like a old school workshop, would also say that they are 3 phase. why the travel steady lying on the floor. Well, it is NOT a school it is the basement of my house. And, yes, I do have a three phase supply. As for the steady lying on the floor it is there because that is where I put it when I finished using it wavering Edited By wavering on 19/08/2012 20:43:07 |
16/08/2012 10:07:43 |
Posted by John Stevenson on 16/08/2012 09:16:45:
Posted by Ady1 on 16/08/2012 00:37:51:
Oka-y I'll take a couple of steps back (after falling out of the pub tonite)
How come you have a Harrison and you don't know what you're doing?
How come people own Audi's and can't drive ?
How come people answer questions on this forum and can't sort thier own problems out ?
Answers on the back of a £20 note please.
John S.
How did you know I have an Audi? Anyway, the problem is the 3-Jaw chuck. It looks like it has been excessively tightened and the outer jaws are bent out sort of if you follow me So, does anybody know where in the Manchester area I could get this sorted? Thanks everybody, this is a great forum Bob
15/08/2012 20:54:01 |
Posted by David Littlewood on 15/08/2012 20:00:38: Two things that haven't been mentioned are the type of tool you are using and the depth of cut. I think you have hit the nail on the head there. I was hoping for an excuse to buy a new lathe but I think this is a case of pilot error rather than machine error ... I will extend my range of tools, sharpen them and get them at the right height and report back in due course Thank you everybody for your comments Bob
15/08/2012 19:54:41 |
Posted by Neil Greenaway on 15/08/2012 19:38:40:
If you face off the end of a bar do you get a pip left in the centre - if so your tool is set low - the diameter of the pip being twice the distance that your tool is below centre. No, I have got it right now - see my post above with pic in it Regards Bob |
15/08/2012 19:24:28 |
Posted by Nathan Sharpe on 15/08/2012 19:01:26:
Hi Bob, If you need a handbook/partslist go to www.lathes.co.uk. Tony has quite a bit of info onsite and sells a handbook for the L5. Thank you - it seems I do have an L5 It sounds to me like you are cutting below centre and light cuts. Yes, I did mention that I added a shim and now is dead centre. Yes, re light cuts, I assumed that a light cut would give a better finish?! Presumably the answer to that is "no" Nathan, this is my best so far ... is this what lead you to conclude I was cutting low and light? Bob
15/08/2012 18:20:22 |
Posted by Neil Greenaway on 15/08/2012 18:09:03:I had to remove the lid from the headstock of course
Is there an idiots guide to doing this anywhere, Neil? Or is this best left to competent people? Bob |
15/08/2012 18:04:40 |
Posted by Russell Eberhardt on 15/08/2012 16:31:22:
The age shouldn't be a problem I started with a lathe about 100 years old. If it's knackered you can fix it/get round it. OK Try rubbing the cutting edge across the back of your fingernail. If it won't produce fine shavings sharpen it. Pased that test Make sure there isn't any play in the headstock bearings they should be tight enough so that without the drive connected if you spin the chuck by hand it won't do more than one or two revolutions before stopping. Feels OK on that test too Make sure the gibs are tight enough. Er ... waht are gibs? Is there any possibility of the tool movine in the toolpost or vibrating? No but I think the tool was too low - have added a shim and now a bit better Keep the tool tip as close to the toolpost as you can. Noted Does the lathe vibrate much when in drive? No, it is fine Not familiar with this site so hope this post looks OK. Thanks for your help Russell I have photographed a pic (Photo 1) of my best efforts done a few minutes ago. How does that look? Bob |
15/08/2012 15:29:10 |
I have a Harrison lathe which has defintely got a bus pass and probably a free TV licence too No matter how carefully I turn things it looks like rats have been gnawing at it. As far as I can see there are 3 possible explanations 1. I don't know what I am doing 2. The tools are blunt 3. The lathe is knackered Or all three Any suggestions as to the best way forward? Bob
