Member postings for JoeT
Here is a list of all the postings JoeT has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco 290V comments n feedback
02/01/2015 14:20:28
Posted by Bogstandard2 on 02/01/2015 13:14:56:
Joe,
Many people will send you off looking for expensive toolposts and holders, well the toolposts might be reasonable, but spare holders can cost you a small fortune.
The last couple of lathes I have had I equipped them with the Aloris or AXA type toolpost, we call them piston ones here, and couldn't find fault with them, plus to kit them out with lots of holders is usually reasonable as well, in fact, it is very easy to make your own to whatever holding size you want. I am just about to make a dozen half height ones to hold really small tooling for those finicky jobs.
Toolpost on my new lathe
Fairly easy to make holders
And lots of 'em
Edited By Bogstandard2 on 02/01/2015 13:15:23
Cheers John - that's the sort I was after - look to be about £100 odd for one with a few holders. I'm very impressed by your DIY holders - since I have a mill too, I really have no excuse not to have a go!
02/01/2015 11:56:43
Very nice pics George!
What size tools are people using with the WM290? I got some nice Glanze 12mm tools for Christmas (Warco told me 12mm was right when I bought the machine), but they need a lot of shimming up in the stock tool post to get anywhere near centre height.
After just 5 mins of test cuts, I'm hating the stock tool post enough to want to splash out on a quick-change. Do I just go for the Warco one, or make/modify another one?
Cheers,
Joe.
18/12/2014 22:25:51
Hi Mark - what does your stand look like - do you have any pics you could post? Mine has three little drawers on the left, 2 shelves in the middle, and a tall cupboard on the right. It seems pretty sturdy to me, but I haven't had a chance to try leveling it up yet, or done any test cuts either.
25/11/2014 23:15:55
Well my WM290V arrived today - I'm curious to see how straight and level my stand is having seen George's pics!
It is one beast of a 'hobby' lathe - I forgot to allow for the effect of seeing it in a big exhibition hall - I think it will make my WM18 look puny!
Thread: What should I budget for getting a workshop wired up?
27/10/2014 10:39:36
Just a quick update - I've purchased 3 Geweiss GW 66015 sockets which seem really nice - good for 32A and interlocked so that you can't turn them on without a plug fitted, and can't remove the plug with the power on.
I have a couple of electricians coming over this evening to give me quotes - I will let you know how I get on!
Thanks for all the help and advice so far!
Cheers,
Joe.
27/10/2014 10:35:50
Posted by Mark Tyldesley on 27/10/2014 10:21:43:
Hi All,
Just back from hols, and set about setting up the lathe with the adjustable mounting feet, managed to get it all leveled out, but lathe wobbles on the stand if pushed slightly, which in turn is going to effect lathe bed ect,Something tells me this is unacceptable and maybe I should bolt the the stand to floor and do all adjusting from tail stock end, or can I get away with this slight wobble? Suggestions very welcome!
Edited By Mark Tyldesley on 27/10/2014 10:23:15
Do you mean that there is movement between the lathe and the stand or that the stand and machine are wobbling together? If it's the latter, I'd be worried about the whole heavy thing tipping over on you!
BTW having been to see one myself at the Midlands show, I have ordered a WM290V - and hopefully it'll arrive this week. I will be sure to share any setup issues/secret-suss I discover with all you guys.
Cheers,
Joe.
17/10/2014 12:08:48
Posted by Bob Brown 1 on 17/10/2014 11:07:46:
If you are adding say 4/5 high power outlets there is nothing to say you can not run these as a ring main in say 6mm cable as apposed to 10mm as the load is fed from both ends of the ring.
Bob
True, but I think I'd prefer to have the high power sockets on a breaker per socket so that I can isolate them individually.
17/10/2014 08:52:59
Posted by Bob Brown 1 on 17/10/2014 07:38:38:
I would be inclined to fit the conduit, run the cables, fit the sockets to the walls etc and let the sparks connect it all up including all outlets/switches then test/certify.
Bob
Yes, I will ask about that - I was thinking 2.5mm for the ring main and probably 10mm rather than 6 for the high current supplies - for a few more quid, I'd be able to plug in my welder into any of the high current sockets, rather than just one extra high current one.
Some people have suggested that a ring would allow the easy addition of extra sockets later - I can't visualise how that would work if you need to loop the cable through a new box though - I probably want to run my conduit above head level to keep the wall free for machines.
17/10/2014 00:14:18
I think I'm at about £500 in parts alone on my little spreadsheet which doesn't seem too bad to me.
Do you think it's reasonable to ask an electrician if I can put up all the conduit and source and place all the sockets where I want them on the walls and then just have them do the wiring? I don't really want to pay a sparky to do the cosmetic bits, and the layout is rather important if I'm going to be able to squeeze everything in.
I could probably do all the wiring myself apart from hooking the new supply up to the incoming mains, but I can fully understand why an electrician wouldn't want to certify wiring they hadn't done themselves, so I'm not going to ask for quotes for that.
Cheers,
Joe.
16/10/2014 23:50:38
Posted by Spurry on 14/10/2014 19:06:20:
You may want to look at the Gewiss range. I use the GW66015 and GW66004. The place at the top of a Google search seem very good.
Pete
Thanks Pete - I think I've found the same things myself on Rapid Electronics' site.
14/10/2014 13:59:04
Posted by Baldric on 14/10/2014 13:51:16:
Posted by JoeT on 14/10/2014 13:15:36:
Cheers Bob - yes I was planning to use industrial connectors for the higher current supplies. The welding college has some sockets with a built in rotary switch that supposedly don't let you remove a live cable, or plug into the socket when it's 'on', but from the red colour on the plugs and the warning labels, I guess this might just be because they're 400V 3-phase. I will have a look for single phase 16/25A 230v ones.
Joe, I know those sockets and have seen them for 240v 16A with RCD so assume they are still available, the only issue I find with them is the number of people who can't get their equipment to work, the turning of the plug is not obvious.
Baldric
Hi Baldric - no, the ones I have in mind have a very obvious 50mm+ diameter round on/of switch - up for off, right for on IIRC. I have seen the ones with RCD's in them on the Screwfix site - I didn't realise that they had the issue with rotated plugs.
14/10/2014 13:15:36
Posted by Bob Brown 1 on 12/10/2014 13:08:35:
The Sparks should have no problem adding in a sub main after the meter/main fuse as they just need to remove the main fuse, there is a debate by some as to the legality of breaking the seals but most suppliers accept the need.
All sub mains need a fused isolator for the meter tails to connect into with the sub main from that.
Cable size and type for the sub main will depend on location of additional CU and if the cable runs external the it will need to be armoured cable, a 6mm SWA cable would be capable of 60 amps but length will reduce that figure.
For welders or large power connections I would be inclined to use a separate socket industrial 3 pin type something like these **LINK**
Bob
14/10/2014 13:09:48
Posted by Bob Brown 1 on 14/10/2014 08:03:20:
I think the installation is a TT system with no supplier earth but an earth spike and an earth cable back to CU then on to the ELCB hence the single earth wire in the picture.
This system is common where the incoming cables are overhead.
As the garage is internal then it should not present any problems adding a sub main and I doubt the earth system will require any changes. If the garage was external then a separate earth spike would be required.
Not forgetting that cable sizes are now larger than they were in the past and that includes earth conductors.
Bob
I'm having a bit of trouble keeping up with the speed of this thread, but, yes Bob & Emgee, the property does have incoming overhead power cables.
12/10/2014 12:28:52
Posted by JohnF on 12/10/2014 11:56:56:
regards JohnHi Joe, What I have is from the main consumer unit in the house is a sub main to both the garage and my workshop, two sub mains, then each location has a consumer unit with RCCB's etc.
Regarding welders my mig woks just fine off a standar socket but I was having a problem with my Tig.which is a small industrial unit, a bit old but quite sofisticated, this tripped the power on startup so consulted a pal who is a competent spark and he fixed it by fitting a different rating or type of RCCB these are rated by different letters which will solve the problem with welders start up current draw. You need to mention this to your spark and he will be able to advise. If you need to know what I have fitted PM me and I'll send you or post the details.
Regards John
Cheers John, yes TIG is what I'm after - I'm doing an evening course at the moment, but it's tricky not being able to practice outside class. And in a chicken-vs-egg kind of way, I only took the training because I can now probably have a TIG setup at home...
12/10/2014 12:24:20
Posted by Bob Brown 1 on 11/10/2014 12:13:52:
The main fuse on the incoming supply should give you an idea of how much power you can pull off the supply, I would be surprised if you could actually pull the full load if the main fuse is old. The CU breaker current does not have any bearing on how much power you can pull, the rating on them is only an indication of what load they are rated for. It is not unusual to see a 100 amp main breaker in the CU but only a 60 amp main fuse. The circuit's within a domestic environment have a level of diversity applied to them, this is where it is not expected for every thing to be on at any one time e.g. a couple of 7kw electric showers and the cooker and hob all pulling full load as that would most likely blow a 60 amp incoming fuse.
I would take a supply for the garage off the incoming supply through a fused breaker at the meter and then on to a garage CU.
I suspect your 60's breaker is in fact a 60 amp fuse.
Bob
Hi Bob - thanks for that - it hadn't even occurred to me to think of getting the new CU run directly from a new fused supply after the meter. This would also prevent me tripping out the main CU if anything in the garage tripped an RCD - as others have mentioned, that's not ideal, to say the least!
Here is a picture of the old bits in my fusebox - I'm no expert, but to me that looks like an incoming fuse and some sort of resettable breaker...
fusebox I am guessing I'd need to get the leccy board involved to wire up another fused breaker post meter - unless the sparky is mad enough to work on live, unfused mains!
I'm not sure who 'the leccy board' is these days - is it the people I send the money to, or the consumer-facing side of the national grid?
11/10/2014 08:53:40
Thanks for all the replies guys - and sorry for giving so little info in the first post!
We have just moved into a 1960's house with an extension built in 2000's that contains the attached garage I plan to use as a workshop for spannering and machining, though probably not both as once!
The garage is about 1.5m away from the existing CU, which doesn't seem to have any spare circuits. The CU's main breaker is 83A but there seems to be some 1960's breaker rated at 60A between it and modern digital meter. I really need to get a sparky in to tell me how much power I can really pull at once, and whether or not that 60A antique can/should be uprated to meet more modern standards. There are currently 2 40A breakers in the CU for the 2 power showers, I may have to negotiate with the mrs about hijacking one of those! Everything in the existing CU seems to be on 2 RCCB's - one for lighting and one for everything else.
The garage already has 4 13A sockets, on a circuit shared with the rest of the extension. I would really like to get these and any other sockets in the garage wired into a new CU in the garage itself so that I can isolate things from within the garage.
I agree with the suggestions of putting in another ring with room for expansion - I'm hoping I can find a sparky who will at least let me run all the trunking and position all the outlets myself, even if he/she will do all the actuall wiring. I would like to run individual feeds from the new CU in the garage to each of the high power circuits.
I don't plan to be welding while using my lathe, but I do plan to CNC all the machine tools, so I do expect them to be drawing upto 13A each and a couple to be running at once - I will probably need cooling rather than heating!
I am also a big fan of not being electrocuted, so I plan to have RCCB's on every circuit in the garage - I'd like to be able to trip something in there without tripping the main house RCCB if possible.
Anyway, I guess I need to find a few decent sparkys and get a few quotes.
Cheers,
Joe.
10/10/2014 08:19:42
Posted by JasonB on 10/10/2014 07:39:56:
I can't really see why the rest of the machine needs beefing up just because its got a larger spindle. You can turn the same dia work with same depth of cut & feed with either bore machine it just means you can fit a longer length of it down the spindle
Go to the next size up Warco say the 12/30 and that also weighs 500kg but you are really jumping up into the next size range of lathes much like the Optimim range
Fair enough - I was just worried that boring a bigger hole in the same size castings as the 280V might not leave much metal in them...
10/10/2014 00:03:26
I'm thinking about a WM290V myself, and am planning to go to the exhibition in a couple of weeks to see one, but I'm wondering whether the 290V is robust enough for its larger spindle bore. While looking at an Opti BF46, I also had a quick look at their 38mm bore lathes, and IIRC they were over 400kg for a similar bed length! Is there enough metal in the WM290V's head castings for its larger spindle and 1.5kW motor?
09/10/2014 23:28:59
Hi guys - obviously I am going to need to get some quotes from some electricians, but very roughly, what sort of budget would you think I'm going to need to get a new consumer unit with RCCB's and a few high current sockets (16/25A) in an internal garage?
I'd really like a welder and a higher HP single phase machine tool or two, so I don't think the existing 13A sockets will cut it.
Cheers,
Joe.
Thread: syil vs tormach
15/08/2013 12:55:29
Are there any happy Syil owners out there with parts & insights they'd like to share?
Cheers,
Joe
