Member postings for Andrew Millar
Here is a list of all the postings Andrew Millar has made in our forums. Click on a thread name to jump to the thread.
Thread: Lynx
01/03/2014 17:48:18
Hi Jonathan thanks for the help they look good will give them a go
27/02/2014 20:48:36
HI Jason the head is tappet for a 5mm thread the union end is bigger when I look at the final assembly pitcher
27/02/2014 18:49:57
thanks for your help it was a 5mm thread and 4 or 5 mm pipe my local baring supplier may be addle to get them thanks again for the help
26/02/2014 20:41:25
Hi all building a Lynx A3 engine the drawing is asking for a M5 compression union can any one tell me were to get them had a look on net with no luck would be very grateful for any help
Thread: piston ring
11/06/2013 20:30:14
Thanks for your help will let you know how i get on
11/06/2013 20:12:43
Thank Moderator can get GR 17 cast iron from the people i get my material from ,will give that a go. Did try oil quench them in oil- this helped
Thread: axminster
11/06/2013 19:03:18
Hi all just a note to let you know i got a rotary table from Amadeal let you know when it gets to me what it is like and thanks for all the advice it was appraciated
Thread: piston ring
11/06/2013 18:56:17
Thanks gays for all the help will get some S G iron and make some more rings and go from there
10/06/2013 19:10:38
Hi al.l made piston rings for my lynx engine out of cast iron ggg40 after heating to cherry red and letting cool the rings are still very flexible .Any rings i worked with in the past have been very brittle. Any advice will be apecciated
Thread: axminster
27/01/2013 18:33:01
Hi. Thanks for the advice. I was going to get an Axminster because it had 4 slots in the table but i might just go for the Vertex because it will be easier to fit a three jaw chuck on to. I am thinking of going to Manchester for the show so I will have a look then. thanks again for the advice Andrew
25/01/2013 18:21:00
Hi all I'm new on here and must say lots of good stuff. Looking for advice on a 150mm Axminster rotary table for my mill are they any good? Grateful for any advice. Thanks
