Here is a list of all the postings Robert Merwiak 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Bent woodworking lathe spindle |
26/09/2020 12:33:25 |
Posted by Brian Wood on 25/09/2020 17:36:11:
Hello Robert, Is it badly bent? I ask because I have straightened a 3/4 inch diameter shaft from a screwcutting gearbox that had been abused by rough handling [forcing gears to ride over each other] I made two softwood Vee blocks and belted the thing with a lump hammer via a length of 3 x 2 inch hardwood to the point where it ran true within a couple of thou over the length when held in my good lathe chuck. The job took most of the afternoon and I sweated off several pounds! Perhaps worth thinking about Regards Brian PS You have a press I now recall, you could use that with care with the spindle supported on wooden Vee blocks Edited By Brian Wood on 25/09/2020 17:40:49 Certainly an interesting option, Brian. It certainly would give me the opportunity to forgive my press seeing it was that which was at fault....ahem... |
26/09/2020 12:07:11 |
Posted by Ian Parkin on 25/09/2020 14:09:33:
Can you post a photo of what you have and some rough dimensions or what model lathe it is. i make spindles and chuck adapters for many ww lathes Edited By Neil Wyatt on 25/09/2020 14:19:38 Ian, I see there is actually a machine for sale in Cambridge (not far from me) at the moment. Sale end is Monday so I will see what price it goes up to and see where to go from there; at least that will give me a few spare parts etc. Many thanks for your offer. |
26/09/2020 12:05:31 |
Posted by RobCox on 25/09/2020 18:47:12:
Hi Robert, I may well be able to help you. I'm just south of Cambridge so not too far away. If you PM me a phone number or email address, perhaps we can sort something out. Rob Thanks, Rob. I see there is actually a machine for sale in Cambridge at the moment. Sale end is Monday so I will see what price it goes up to and see where to go from there; at least that will give me a few spare parts etc. Many thanks for your offer. |
26/09/2020 12:03:09 |
https://www.clarkeservice.co.uk/manuals/wood_lathes/cwl12d.pdf |
25/09/2020 16:34:20 |
Posted by John Baron on 25/09/2020 16:06:00:
I'm sure "Machine Mart" would happily supply a new spindle ! Hello John, I went to Machine Mart, I believe they sent me on to Clarke. |
25/09/2020 14:29:14 |
Can you post a photo of what you have and some rough dimensions or what model lathe it is. i make spindles and chuck adapters for many ww lathes Edited By Neil Wyatt on 25/09/2020 14:19:38 Hello Ian, it's safely filed in the shed at the mo, will get it out and take measurements. It's a Nutool 37-2, it's the same as the Clarke 37" woodworking lathe; I believe the Nutool became the Clarke at some point because I was sent in Clarke's direction when seeking a replacement part. Rob |
25/09/2020 14:13:54 |
Posted by Jeff Dayman on 25/09/2020 14:06:00:
What country and city are you in Rob? Would be good to know for those local to you to help. I'm in Newmarket, UK Edited By Neil Wyatt on 25/09/2020 14:19:44 |
25/09/2020 13:20:34 |
I wanted to change the bearings on my woodworking lathe... I decided to use my 12 ton press to remove the bearings, unfortunately I didn't realise there was a 'shoulder' (for want of a better word) on the spindle at one end and the bearing would only come off one way, I was trying to go the other way, after a few tons of 'she'll move soon you know'...I realised my mistake. I cannot find a replacement anywhere, it's an old lathe. Would anyone know where I might get a new one made as a one off for reasonable price, or of course, would anyone here be able/willing to help? Would appreciate the help because I really like the style of lathe and would rather fix than dump... Regards, Rob Edited By Neil Wyatt on 25/09/2020 14:17:48 |
25/09/2020 13:13:35 |
Hello everyone, name's Rob, old timer from Newmarket, UK. I joined because I was hoping someone might be able to help me...won't say more here, will post in appropriate forum. Cheers. |
