Here is a list of all the postings Peter Andersson 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Electric Motor RPM? |
11/05/2012 09:59:29 |
Thanks Ian, yes; they are both controlled by the 60Hz, but one of them will rotate 3 times as many as the other one in any given time. If the controlling factor of the motors is the alternating current, i.e. the pulsation of the mains supply, then my take on this would be that the motor that receives the most pulsations per revolution, is the better controlled one...or is this simple logic flawed? the higher the pulsation per revolution ratio, the better... |
10/05/2012 15:08:00 |
Hi, I have 2 electric, single-phase hysteresis synchronous motors, one is 1/100HP, 1800RPM and the other one 1/500HP, 600RPM. Both are 117V/60Hz motors. The 60Hz, I'm guessing, means that there are 60 electrcal pulses/second that "control the motor. The bigger motor does 30 revolutions in a second. During that second, the motor is controlled 60 times by electrical pulsation (60Hz), so every revolution is controlled by 2 pulsations. The smaller motor, on the other hand, rotates 10 times every second, so every revolution should in this case be controlled by 6 electrical pulsations, i.e. being better controlled by the 60Hz AC. I know this might sound like a stupid reasoning, but I felt I had to get my head around this, since I got both motor options available for a project, and felt that the smaller motor might be the more "accurate" one, however academic this might be in real life. Grateful for any kind of constructive input - Thanks!!! Edited By Peter Andersson 1 on 10/05/2012 15:10:10 |
Thread: Cracks in mill-to-lathe attachment Hobbymat MD65/BFE65 |
18/04/2012 13:43:28 |
Hi Mike, I've replied by sending you a PM - and MANY THANKS again!!! /Peter |
17/04/2012 23:46:41 |
Posted by Mike Rose on 17/04/2012 23:28:39:
Peter I have one of those unused (by me). I will check it is undamaged tomorrow . If you are interested you can have it for£5 plus postage.
Hello Mike!
That was fantastic news!!! Thank you very much!
/Peter
17/04/2012 18:17:05 |
Thanks KMPand everyone else who replied - so much good input and so fast I've made a mistake in my info...the two bolts with the fracture lines next to them are actually alignment bolts too. The actual fastening bolts ae not visible in that picture, since I removed them. Here's a picture showing those with the corresponding little plate that goes on the inside of the lathe bed. Apologies for that. At the same time, with this design and the aluminium, it's not that hard to see how this might eventually happen.
Edited By David Clark 1 on 17/04/2012 18:32:36 |
17/04/2012 17:42:58 |
Posted by Robert Dodds on 17/04/2012 16:45:21: I too see the new posts with photo detail. How many of those bolts are attachment bolts? Are some just used to jack off and align the base to set it up square. It might suggest that the whole thing has been a bit brutally tightened at some time. The basic repair principal is still valid. Bob Edited By Robert Dodds on 17/04/2012 16:56:46
Hello Bob, Russell and David, and thanks; 2 bolts on each side of the main part, (where the mill column slides in) are connecting bolts, the other 2 (1 on each side) is for levelling. The 2 connecting bolts (on one side) can be seen in my first picture, as well as the fracture lines in the aluminium next to both of them. Definitely a case of overzealous tightening. I was thinking along the lines of a steel strap too and/or angle irons to try to offload the fractured bit and prevent the other side to go too. Cheers /Peter
17/04/2012 16:33:24 |
Hi Ady1,
I see your point,but this attachment actually is a cast block of aluminium, approx 7"x5"x3.5". I'm not knowledgeable enough to be able to procuce this size & shape. I was thinking along the lines of whether there's a possibility to repair (weld?) these cracks, or if I could have a steel backing plate made to support the "wings" of this block (i.e.the parts of the attachment bracket with the holes and bolts in it)? Edited By David Clark 1 on 17/04/2012 17:03:23 |
17/04/2012 13:47:56 |
Hi everyone - first post here! I have acquired a Hobbymat MD65/BFE65 lathe/mill. On closer inspection, I found that the attachment bracket for the mill onot the lathe has 2 cracks in it. The material is aluminium, and I'm now wondering what can be done to establish stability and rigidity as far asconnecting the mill to the lathe please?
Any advice is greatly appreciated.
Edited By David Clark 1 on 17/04/2012 17:02:31 |
